Tagged: 2019 R1, cfx, fluid-dynamics, General, General - CFX
March 17, 2023 at 8:58 am
FAQParticipantIn WB, Right-click Results > Properties > Publish Report = [Enabled] -Edit the Design Of Experiments cell > Preview -Before clicking update (to solve the DPs), right click the DPs you want to retain the report form > Insert as Design Points -This will save the report images the corresponding dp# folder
- Skewness in ANSYS Meshing
