Tagged: 17.2, fluid-dynamics, Scripting/Journaling, workbench platform
August 25, 2023 at 12:15 pm
SolutionParticipantWhen running a project with multiple design points, one thing we can do is turn on the Retain option (click the checkbox under Retain column in the table of design points). This will save the files for the completed design points. However to periodically save the main Workbench project, there is no direct option. It can be done via scripting. One of such scripting example to save WB project is attached.
1. 2046556.zip
- Skewness in ANSYS Meshing
