Tagged: 18, cfx-post, CFX-TurboGrid, fluid-dynamics, General, turbo
June 5, 2023 at 7:05 am
FAQ
ParticipantIf errors occur when initializing TurboPost, such as incorrect number of domains or improper generation of reports and objects, it is best to go back to CFX-Pre and set up the model again. Problems like this may occur if the components are defined out of order. To correct this, redefine the order of the components in TurboPre (Tools > Turbo Mode > advance to Component Definition tab). The descending order of the components in the list should be the same as the streamwise order of the components. Then, in the solver, initialize the correct def file with the previous solution and run a few iterations to achieve the same convergence level. The model will then initialize properly in TurboPost.
- Skewness in ANSYS Meshing
- ANSYS Fluent: Introduction to the GEKO Turbulence Model Part I
