Tagged: 16, fluent, fluid-dynamics, Scripting/Journaling/UDF, turbulence
January 25, 2023 at 7:16 am
FAQParticipantThis can be done using the following scheme command: (rpsetvar ‘flow-time 123.0) The above command will set the flow time of the current timestep to t=123 seconds, for example.
- Skewness in ANSYS Meshing
