June 6, 2022 at 10:33 am
FAQParticipantTo reset ANSYS SpaceClaim Direct Modeler as default,
1. Close SpaceClaim
2. Go in the folder %appdata% and rename the folder SpaceClaim as SpaceClaim.old You could also try to clear the following keys in your registry: – HKEY_CURRENT_USER > Software > SpaceClaim > LicenseReset > Reset – HKEY_CURRENT_USER > Software > SpaceClaim > Primary > LicenseType
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- How to move component within the assembly?
- ANSYS DesignModeler: Weld Feature
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
