Tagged: 14, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantSome of the left-handed face problems can be fixed using the following text user interface command In T-Grid: /boundary/repair-face-handedness In Fluent: /define/boundary-conditions/modify-zones/repair-face-handedness define/boundary-conditions/modify-zones/repair-face-node-order If you are still not able to resolve the issue, check the location of left handed faces in T-Grid using the GUI: Display-> Grid-> Faces->Left Handed Inspect the mesh visually near the left handed faces. Look for any problems in mesh. Check if there is any erroneous element. Take appropriate action to repair mesh.
- Skewness in ANSYS Meshing
