Tagged: 18, Cleanup/Connections, fluid-dynamics, General, meshing, Virtual Topology
August 25, 2023 at 12:16 pm
SolutionParticipantHard points can occur in geometry if a solid is created be revolving a sketch about an axis. These point can cause mesh to cluster around the points. To remove them, use Virtual Topology with Simply Faces=Yes. Please see attached video for steps. Keywords: hard points
1. 2049086.zip
- Skewness in ANSYS Meshing
