Tagged: 17.2, designmodeler, fluid-dynamics, geometry, Modify Geometry, Other
June 5, 2023 at 7:05 am
FAQParticipantTo temporarily disable the body, use Suppress by right-clicking on the body in the Tree Outline and selecting Suppress. If you want to permanently remove it, go to the Create menu, mouse to Delete, and click Body Delete (in versions before 14.5, go to Create – Body Operations – Delete).
- Skewness in ANSYS Meshing
