May 15, 2023 at 8:32 am
SolutionParticipantIn the solver mode you can use the ribbon: Setting Up Domain > Zones > Append > Append Case File… (See also ANSYS solution 1306) Alternatively, you can use the meshing mode to read as many meshes as you like simultaneously. For more details refer to the attached document.
1. 2054143.pdf
- Skewness in ANSYS Meshing
