Tagged: 19.2, General, mechanical, static, structural-and-thermal, structural-mechanics
April 13, 2023 at 7:32 am
Solution
ParticipantPlease refer to the attached documents to access the solution.
1. 2055728.zip
2. 2055728_Solution.pdf
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
