How to proceeed when the results file interpolation fails with the following error message: Workspace size MXL is too small STOP called from routine INTER1 An error has occurred in cfx5interp: The CFX-5 Interpolation Program exited with return code 1
March 17, 2023 at 8:58 am
FAQParticipantThis error message is due to a wrong memory estimation, which can occur for long thin meshes, e.g. large differences in dimensions. As workaround the interpolation can be started from command-line with the following command: cfx5interp -dest name.def -res name.res -mxl
By default, is set to 1/3 * (No. of vertices in the definition file), so try a number 10-100 times higher.
- Skewness in ANSYS Meshing
