Tagged: 17, 2D axisymmetric free surface, fluid-dynamics, General, polyflow
August 25, 2023 at 12:15 pm
Solution
ParticipantOriginal Error: *** WARNING *** from [matr16] The radial coordinate of a free surface node is negative, The step will be started. You can fix that switching on the Upwinding for the free surface. Please see attached video.
1. 201612.mp4
- Skewness in ANSYS Meshing
