How to prevent automatic connections creation in ANSYS Meshing for Interface in Fluent parametric study
Tagged: 19, fluid-dynamics, General, workbench, workbench platform
May 15, 2023 at 8:32 am
SolutionParticipantAutomatic connection creation in ansys meshing gets imported in Fluent and generates separate interfaces apart from manually name selected created interfaces. This can lead to issue of modeling issue. To prevent this for base design point delete the contacts folder also along with contacts. Also right click on connections option and disable the connection option.
- Skewness in ANSYS Meshing
