Tagged: 16.2, buckling, mechanical, structural-and-thermal, structural-mechanics
March 17, 2023 at 1:12 pm
SolutionParticipantSee the presentation attached to this solution. Note this was originally presented as a Webinar in French. The Webex recording can be viewed at https://ansys.webex.com/ansys-fr/lsr.php?RCID=e6b2c8f4acd44f38a3270c29c2333534 The original presentation in French is also attached
1. 2042339 ENG.pdf
2. 2042339 FR.pdf
