Tagged: 19.1, General, mechanical, static, structural-and-thermal, structural-mechanics
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attached documents to access the solution.
1. 2055670.zip
2. 2055670_Solution.pdf
