Tagged: 19.1, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantOne may insert a convergence object under the stress and then enter the allowable change. Also try changing the maximum number of refinement loop and depth needed under the Solution tab.
