Tagged: 17.2, BCs & Interfaces, fluent, fluid-dynamics, materials, Reactions, Species/Reactions
June 5, 2023 at 7:05 am
FAQParticipantDuring process, moles does not have to be conserved. Mass is the one that should be conserved. Mole fraction definition is simply number of moles for species i/total number of moles. To examine if your species is conserved or not use this TUI: /report> smf This will tell you about the mass balance of each species in kg/sec and you can compare it to your DPM sources.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
