August 25, 2023 at 12:15 pm
SolutionParticipantIn DM, you can not use pattern in sketching mode. It can be used for 3D bodies. Please see attached video for workaround for copying and patterning in sketch mode. Keywords: pattern, sketch pattern, 2d pattern
1. 2050481.zip
- Skewness in ANSYS Meshing
