General
General
How to parametrize patterns in SCDM
    • SolutionSolution
      Participant
      If a linear pattern is already created, then use the Select tool to select one of the instances. You now have the option to modify Count, Spacing dimension and overall dimension. Select one of the dialog boxes for either and click on Create Group in the Groups tab. (If a circular pattern is already created, your options are Count, Radius and spacing angular dimension.) The document is attachment was done in a previous version of SCDM but it is still valid in 2019R1.
      1. 2048610.pdf
