How to overcome the following error?: The /MENU command is either not available for this version of ANSYS or the appropriate product was not selected for this session.
Tagged: 19, General, mechanical, static, structural-and-thermal, structural-mechanics
April 13, 2023 at 7:32 am
SolutionParticipantThere are two options: 1. Follow the steps described in the attachment. Things like Windows updates, system crashes, hard shutdowns, etc., can impact your settings, so cleaning them out on occasion is a good thing. ? 2. If this does not help then uninstalling and reinstalling is the option.
1. 2055331.pdf
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
