Tagged: 17.2, FLUENT Meshing/Tgrid, fluid-dynamics, General
June 5, 2023 at 7:05 am
FAQParticipantYou can output a mesh file in STL format with the following command: /file/export/stl
- Skewness in ANSYS Meshing
