June 6, 2022 at 8:32 am
FAQParticipantHere are the ISAT (In situ adaptive tabulation) table data Output and Input methods:
1. Output Method. Run the following TUI command, then specify an output filename: /file/write-isat-table
2. Input Method. Run the following TUI command, then enter the input filename: /file/read-isat-table <> Note: appropriate reacting flow models requiring ITAS table must be active for this command to be shown in TUI
- Skewness in ANSYS Meshing
