Tagged: 17.2, designmodeler, fluid-dynamics, General, geometry
June 5, 2023 at 7:05 am
FAQParticipantTo obtain body, face, edge, or vertex information, select the object from which you want to obtain information from the Selection toolbar and select the target on the Graphics window. The acquired information will be displayed in the status bar (at the bottom of the screen) or the Details View window. The kind of information that can be obtained is as follows. Body: volume; surface area; number of faces, edges, or vertices that make up the body Face: area, number of edges or vertices that make up the face Edge: length Vertex: coordinates
- Skewness in ANSYS Meshing
