Tagged: 16, fluent, fluid-dynamics, General, General - FLUENT, parallel
January 25, 2023 at 7:16 am
FAQParticipantThe following text command can be used to find out the cpu time taken in solving each model equation: (print-model-timers -1) For parallel, -1 is replaced by 0,1..(compute node id ) to find out the time taken on a given compute node for each equation.
- Skewness in ANSYS Meshing
