Tagged: ansys-fluent, assembly, component, design, move
June 6, 2022 at 10:33 am
FAQParticipant1. Move the component within the assembly – Select the component from the structure tree and click Move to change its location
2. Move the solid body within the component – Open the individual component (click RMB on component and select “Open Component”) and move the Solid geometry What you will notice is that if you open an individual component, it has its own coordinate system. Every item (Solid, Surface, Curve, etc) can be moved inside of a model. This affects its position relative to its own coordinate system. In the assembly, you mostly deal with the main coordinate system. However, if you open a single component and move the solid body, you may notice a change in the position within the assembly. This can be prevented by defining assembly conditions like Align, Orient, and Tangent in order to reduce the degrees of freedom.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS DesignModeler: Weld Feature
- How to move component within the assembly?
- ANSYS SpaceClaim: Imprinting Geometry
- ANSYS SpaceClaim: Shared Topology
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
