Tagged: ansys-fluent, cht, interface, Moving CHT interface, Wall Heat Flux
June 6, 2022 at 8:32 am
FAQParticipantProblem/Description:
Conjugate heat transfer (CHT) simulation with respect to mesh morphing: The solid is moving with a solid body motion, the fluid domain is partly following by means of mesh morphing e.g. piston of an internal combustion engine. Monitoring ‘areaInt(Wall Heat Flux )@Domain Interface 1 Side 1’ at the fluid side of the moving CHT interface provides wrong values.
Solution: On a moving interface the wall heat flux values do include the complete enthalpy flux across the interface. They also contain the pressure work (Pressure*Area*Velocity) at the moving fluid/solid interface. The correct wall heat flux is available at the solid side of the interface. Monitoring ‘areaInt(Wall Heat Flux )@Domain Interface 1 Side 2’ contains the right value.
- Skewness in ANSYS Meshing
