June 6, 2022 at 8:33 am
FAQParticipantThe coefficient loop iteration number can be monitored with the built in variable aitern. For example, if a monitor point is created based on an expression equal to aitern, the number of coefficient loops for each timestep will be returned. See Section 16.2.21 Variables and Predefined Expressions Available in CEL Expressions in the CFX Reference Guide for more information.
- Skewness in ANSYS Meshing
