General
General
How to modify the solution animation playback .cxa file
    • FAQFAQ
      Participant
      The solution animation playback .cxa file can be modified if the solution animation becomes corrupt. Consider the scenario where you have .hsf files from 4-9. If you modify the .cxa as shown below and load it into Fluent, the animation will not be displayed. This is because the Frame number doesn’t start at 0. AnimationSequence1.0 NAME: D:/Test Files/Fluent\animation WINID: 3 STORAGE: 5 PLOTANIMATION: 0 FRAMES: 6 Frame 4 5 animationtemp_0004.hsf 3 Frame 5 5 animationtemp_0005.hsf 3 Frame 6 5 animationtemp_0006.hsf 3 Frame 7 5 animationtemp_0007.hsf 3 Frame 8 5 animationtemp_0008.hsf 3 Frame 9 5 animationtemp_0009.hsf 3 Renumbering the Frames, as shown below will allow the animation to load. AnimationSequence1.0 NAME: D:/Test Files/Fluent\animation WINID: 3 STORAGE: 5 PLOTANIMATION: 0 FRAMES: 6 Frame 0 5 animationtemp_0004.hsf 3 Frame 1 5 animationtemp_0005.hsf 3 Frame 2 5 animationtemp_0006.hsf 3 Frame 3 5 animationtemp_0007.hsf 3 Frame 4 5 animationtemp_0008.hsf 3 Frame 5 5 animationtemp_0009.hsf 3
