Tagged: 18.2, contact, General, mechanical, structural-and-thermal, structural-mechanics
March 17, 2023 at 1:12 pm
SolutionParticipantPlease refer to the attachments to access the solution.
1. 2052789.pdf
2. 2052789.zip
