Tagged: 2021 R2, Data Visualization, ensight, fluid-dynamics, General, Visualize Data
April 13, 2023 at 7:32 am
SolutionParticipantFor complicated clips it can be useful to mirror them to re-use the same shape in a different part of the model. There is no option in EnSight to reproduce the clip behavior in a mirrored way, apart from scripting. But it is possible to export the clip, read it in again and then mirror it. To post-process data, it is still necessary to map the data from the original case to the mirrored entity. Keywords: EnSight; mirror; clip; part; mirroring; symmetry; symmetric; casemap; map; mapping
1. 2066629.zip
2. 2066629_EnSight_mirror_clips.pdf
3. 2066629_Mirror_Clips.mp4
- Skewness in ANSYS Meshing
