April 13, 2023 at 7:33 am
SolutionParticipantManually in the GUI, we can select multiple named selections in the group panel, right-click on them and select ‘Merge’. This feature is not available by script but we can get the same results by two approaches. 1) Delete / Create We can collect the members of the named selections, delete the named selections and create a new named selection with all members. 2) Replace We can replace the members of the named selection by a new selection. An example of each approach is provided in attachment. The script can be run on the .scdoc for demonstration.
1. 2058427.zip
- Skewness in ANSYS Meshing
