June 5, 2024 at 8:24 am
Watch & LearnParticipantIn this video tutorial, you will learn how you can measure the projected area of one or more objects in Ansys Discovery.
While doing external fluid flow simulations on a vehicle, the projected frontal area is very important parameter for vehicle design as it has a significant impact on aerodynamic drag. This video will help you measure the area of the projected silhouette and displayed in the design window. With this information and drag force, you can calculate the drag coefficient to compare the aerodynamic efficiency of the different designs.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- Applying Thermal Conductance
