Tagged: 17.2, FLUENT Meshing/Tgrid, fluent-meshing, fluid-dynamics, General
June 5, 2023 at 7:05 am
FAQParticipantPlease follow the procedure below: 1.Go to Mesh > Tet > Refinement tab 2.Click Local Region 3.Specify the area you want to mark 4.Click Define The specified area will now be marked. It is possible to divide the Face Zone and Cell Zone for this marked area.
- Skewness in ANSYS Meshing
