June 6, 2022 at 10:32 am
FAQParticipantPlease follow the procedure below:
1.Go to Mesh > Tet > Refinement tab
2.Click Local Region
3.Specify the area you want to mark
4.Click Define The specified area will now be marked. It is possible to divide the Face Zone and Cell Zone for this marked area.
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
