Tagged: ansys-fluent, Bodies, components, Maintain Relation
June 6, 2022 at 10:33 am
FAQParticipantAs long as you move a component into another component, the instancing should remain as instancing is based on components not solids. If you move solid, then instancing is lost.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- How to move component within the assembly?
- ANSYS DesignModeler: Weld Feature
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
