Tagged: fluent, fluent-post-processing, fluid-dynamics, Other, post-processing
March 17, 2023 at 1:10 pm
SolutionParticipantPlease refer to the attachments to access the Solution. The first video 2058020-19x.mp4 is for all the versions up to 19R2 version. The second video 2058020-2019R1.mp4 is for the version starting at 2019R1. For the previous versions to 2019R1 – create a cell register based on cell quality: “Cell Equivolume Skew” (“Orthogonal Quality” can be chosen as well) In Adapt>Mark/Adapt Cells>Iso-Value select Mesh and Cell Equivolume Skew, and enter 0.99 and 1 as Min and max namely. Click on Mark to validate The number of marked cells will be displayed in the TUI panel – display the marked cells In Adapt>Manage Register panel, select the register you just created and click Display You can adjust display by setting the appropriate settings in the Options… box
1. 2058020-19x.mp4
2. 2058020-2019r1.mp4
- Skewness in ANSYS Meshing
