General
General
How to load the material libraries from user defined libraries using TUI..?
    • FAQFAQ
      Participant
      1) read the user defined materials library in the materials properties in ANSYS Fluent /def/materials/data-base database-type user-defined my-mix.scm here, the library name being my-mix.scm 2) now, load each material based on it’s type ( fluid or solid ) using TUIs as follows: /def/materials copy fluid air /def/materials copy solid copper
