March 17, 2023 at 8:57 am
FAQParticipantThe following is the Python command for loading a session file: ensight.objs.ensxml_restore_file(r”””test.ens”””) If this command is put in a .py file, EnSight can be run from the command line with: ensight102 -p loadsession.py, which will run the Python file, and in turn load the session file. Similarly, the following is the Python command for loading a context file: ensight.file.restore_context(“test.ctx”)
- Skewness in ANSYS Meshing
