June 5, 2023 at 7:05 am
FAQ
ParticipantThough there doesn’t exist a direct option to invert selection, there is a shortcut for it. The shortcut is “Ctrl+Shift+I”. Using this shortcut, selection can be inverted. For selected edges and faces, the selection gets inverted for respective bodies. For selected bodies, selection gets inverted for remaining visible bodies.
- Skewness in ANSYS Meshing
