How to interrupt a meshing run without a pop-up window. We do not see the pop-up window. Is there anything in the settings we need to adjust?
June 5, 2023 at 7:06 am
FAQParticipantIf the Meshing progress dialog-box is not visible then the best way to fix it is by resetting the ANSYS configuration stored in the Appdata folder. Save and close all open instances of Workbench Type %appdata% in the windows explorer address bar then browse to AppDataRoamingAnsys folder Here you will see a folder named v172. Rename that to v172_old. Now reopen Workbench project. The meshing progress dialog-box should appear.
- Skewness in ANSYS Meshing
