August 25, 2023 at 12:16 pm
SolutionParticipantIn order to get the ANSYS Electromagnetics Products available in ANSYS Workbench Toolbox, we need to integrate ANSYS Electromagnetics Products with ANSYS Products Make sure all the instances of ANSYS Workbench and ANSYS EM Products are closed and same version of the products is installed on the machine Please follow the below steps to Integrate ANSYS EM Suite 18.0 with ANSYS 18.0. •Click the Windows Start button, •Select All Programs > ANSYS Electromagnetics Suite 18.0 •Select Modify Integration with ANSYS 18.0 In the Integration with ANSYS 18.0 window, make sure the option Yes is selected for Do you wish to integrate with ANSYS 18.0? and click the OK button Please see the attached document for detailed instructions
1. ANSYS_Workbench_HFSS_Toolbox.pdf
