How to install MS-MPI service on stand-alone machines. VPN usage may result in analysis failure when using the default Intel MPI.
March 17, 2023 at 9:00 am
FAQParticipantBrowse into the extracted AnsysEM Installation media 1 – install MS MPI
PrerequisitesMS MPI 10.0msmpisetup_v10.0.exe 2 – Start the MS-MPI service by opening an elevated CMD (rt-click on CMD and “run as admin”) and run these three commands: sc config MsMpiLaunchSvc depend= Dnscache/Dhcp sc config MsMpiLaunchSvc start= delayed-auto sc start MsMpiLaunchSvc 3 – set MPI type in AEDT to MS-MPI in “HPC and Analysis Options” -> “Options” MPI Vendor = Microsoft
