Tagged: 19, fluid-dynamics, General, workbench, workbench platform
May 15, 2023 at 8:32 am
SolutionParticipantTo use the previously update design point as initialization, you can set the Design Point Initiation to From Previous Updated in the Parameter Set properties windows.
- Skewness in ANSYS Meshing
