March 17, 2023 at 1:11 pm
Solution
ParticipantPlease see the attached document and model file.
1. 2061017.zip
3. Frictional heating.pdf
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
