January 25, 2023 at 7:16 am
FAQParticipantEspecially in complex cases with many domains and GGI interfaces the convergence of scalar equations (i.e. E-Pot for electric potential) can become slow, resulting in a large number of iterations to obtain a steady state result of the scalar. The following Expert Parameters will ensure a tighter convergence in the linear solver and thus result in reduced iterations for steady state results of scalar. Either use solver target reduction scalar = 0.0005 or mg small grid = 50 solver target reduction scalar = 0.01
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
