Tagged: 19, designmodeler, fluid-dynamics, Modify Geometry, Other, Preprocessing: Geometry
May 15, 2023 at 8:33 am
SolutionParticipantPlease see attachment to access the solution. Keywords: imprint, projection, split, curve, edge
1. 2054045.mp4
- Skewness in ANSYS Meshing
