Tagged: ansys, baffles, Design Modeler, imprint, spaceclaim, Volume Bodies
June 6, 2022 at 10:33 am
FAQParticipantTo work with baffles in ANSYS Spaceclaim Direct Modeler, Volume bodies and Surface Bodies have to be generated/moved in 2 different components at the upper level. To imprint the baffles on the volume bodies, the Share topology option has to be set to Merge between the 2 main components. Example: Design (-> Share Topology : Merge) – Component1 (-> Share Topology : Share) -> Volume Bodies – Component2 (-> Share Topology : None ) -> Surface Bodies
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS DesignModeler: Weld Feature
- How to move component within the assembly?
- ANSYS SpaceClaim: Imprinting Geometry
- ANSYS SpaceClaim: Shared Topology
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
