General
General
How to import stl in watertight workflow?
    • FAQFAQ
      Participant
      Please import stl in SpaceClaim. Then save it as .scdoc. Then use this .scdoc file in watertight workflow. Please note that as it is stl file, it will loose all geometry curvature data. You may also need to extract the edges after importing file in Fluent Meshing. Keywords: stl, faceted, remesh
