March 17, 2023 at 8:58 am
FAQParticipantThere is a an option in the SpaceClaim Options, under File options > STL: Import as Solid/surface body. Check this option on to import STL files as solids. This imports a solid with the same faces as the STL mesh and you can modify the geometry the same way you would edit solids created in SpaceClaim. Check the Merge Faces option to merge the mesh faces during import.
- Skewness in ANSYS Meshing
