Tagged: cad, filter, import, named-selections, spaceclaim
June 6, 2022 at 10:33 am
FAQ
ParticipantIn SpaceClaim options, go to File Options>Workbench and check the Named Selections box Make sure to set the appropriate prefix (“NS” by default) or to empty the Named Selections Key if you wish to import all named entities from your CAD All the imported named selections will be listed in the “Group” tab.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS DesignModeler: Weld Feature
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- How to move component within the assembly?
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
